HEATER BH499 BASE HIT PITCHING MACHINE AND XTENDER 24 FT. BATTING CAGE
Get a hit every time you come to the plate with your personal real baseball pitching machine. Trend Sports introduces BaseHit the most affordable real baseball and lite-ball pitching machine. Complete with a rugged tubular steel tripod and a 12-ball auto-ball feeder the BaseHit plugs into any standard wall outlet. Combined with Xtender 24 Home Batting Cage BaseHit and Xtender 24 become an affordable real baseball home batting system!
Makes it possible to hit live pitches at home. BaseHit and Xtender 24 connect together with the built-in connection harness. This allows baseballs into the cage but they won’t fly out. This revolutionary connection harness allows you to hit real baseballs at home without fear of damage to anyone or anything.
What You Get- BaseHit Real Ball Pitching Machine
- 1 Poly Pitching Machine Baseball for perfect baseball accuracy
- 12 Ball Auto-Ball Spiral Feeder delivers 1 ball every 10 seconds
- Variable speed control &dual bearing electric motor pitches baseballs up to 45 mph.
- 6 in. Wheel cushions the balls and pitches consistent strikes every time
- Rugged composite pitching machine housing to protect you from spinning wheel
- Adjustable pitch height knob to get the pitch height you want.
- Heavy-duty tubular steel tripod stand with pushpin legs for quick assembly
- Built-in machine harness attaches to Trend Sports home batting cages
Key Specification- Real Baseball and Lite-Ball Pitching Machine
- A/C Power
- Recommended Ages: 8 years to Adult
Specification:- Dimension - 24 x 12 x 24 ft.
- Item Weight - 5.4lbs.
Price: 674.99
