The Heater baseball pitching machine from Trend Sports provides a high quality pitching machine at an affordable price. The powerful 1/4 horsepower motor throws baseballs at variable speeds up to 52 miles per hour. The Heater also includes an automatic ball feeder that holds 12 baseballs. Just turn on the feeder and each ball is dropped into the Heater pitching machine every 9 seconds. Take batting practice without the need for another player. And with a simple tilt adjustment you can also catch grounders and fly-balls. Plug the Heater into any standard wall outlet or use it with the optional battery pack for convenience.
Makes it possible to hit live pitches at home. Heater Baseball and Xtender 24 connect together with the built-in connection harness. This allows baseballs into the cage but they won’t fly out. This revolutionary connection harness allows you to hit real baseballs at home without fear of damage to anyone or anything.
