The most affordable combination baseball and slow or fast pitch softball machine available. The Heater Combo is perfect for slow pitch softball and easily converts from pitching baseballs to pitching softballs in minutes. The bonus auto-ball feeder will deliver baseballs or softballs every 10 seconds and supports both ball types. With the variable speed control you can set the pitch speeds up to 60 MPH for baseballs and up to 58 MPH for softballs. The Heater Combo will pitch both 11 in. and 12 in. softballs with variables speeds for fast or slow pitch. And with a simple tilt adjustment you can also catch grounders and fly-balls. Plug the Heater Combo into any standard wall outlet or use it with the optional RollingPower battery pack for convenience.
Xtender 24 Home Batting Cage makes it possible to hit live pitches at home. Heater Pro and Xtender 24 connect together with the built-in connection harness. This allows baseballs into the cage but they won’t fly out. This revolutionary connection harness allows you to hit real baseballs at home without fear of damage to anyone or anything.
