HEATER XT599 XTENDER 48 FT. HOME BATTING CAGE 24 XTENDER 2X
The Xtender 48 Batting Cage is the most revolutionary batting cage ever developed!
The Xtender 48 arrives in two boxes each box contains everything you need for a 24 foot batting cage. Just following the easy instructions and the cages join together to make a 48 foot home batting cage.
The secret to the affordability and durability of the Xtender Home Batting cage lies in the frame design and netting.
- First the frame’s side supports are made of steel tubing to give the frame durability and maximum swinging area for the batter.
- Second the middle arch of the frame is made of flexible fiberglass rod. This rod allows the cage to flex in the wind without bending or breaking.
- Third the six power stakes are staked into the ground to give maximum frame support.
- Fourth a rugged foam pad slides over each frame support to protect the frame from balls.
- Fifth the extra strength catch net is made of 1 in. polypropylene netting compared to 2 in. netting used on other cages.
This smaller netting provides twice as much strength in the same amount of space. In fact this netting is so small it doubles as a golf cage. And because you can connect Xtender cages together you can increase the length of your cage just by ordering another Xtender Cage.
Features:- Solid Steel &Fiberglass Frame
- Foam Padding
- 1 in. Polypropylene Netting
- Steel Ground Stakes and Nylon Support Ropes
- Built-in Pitching Machine Harness
- Works Perfectly with Trend Sports Pitching Machines
Benefits:- Fiberglass poles assemble quickly while adding strength and stability
- Foam Padding protects frame from damage
- 1 in. Polypropylene Netting is durable and strong
- Steel Ground Stakes provide rugged support
- Built-in Harness connects easily to pitching machine
Key Specs:
Price: 809.99
