In-Ground frames are 2 in. square heavy duty galvanized steel tubing. Finish will not chip or flake off like paint. Kits come in 3 frame and 4 frame models. Frame sections can be spaced to fit your net and space requirements. Unique serpentine cable system for ease of net hanging and take-down. Wire cable feeds back & forth across top of frame and attaches to a manual winch. No more climbing ladders through hanging process! Frame dimensions after installation are approx. 11 high x 16 wide ft. Frames are pre-drilled for 14 ft. wide nets. 12 ft. wide applications must be re-drilled on site.
Kit Includesupright poles cross member ground sleeves cable clamps eye bolts. turnbuckles and snap rings.
